Titanone will not run.
nanchonnom
Postby nanchonnom » 19 Mar 2015, 12:29
Hello. Some time ago I bought a Titanone.
Was a program in Windows is not running this program.
starting titan is the only phrase that does not come out any floating menu.
The use of virtualization from VMware window in the current MacBook Pros.
Specifications are i7 2.4g / 8g ram degree specification.
Windows 7 Ultimate has been using K ..
Install the program has installed an Avolites Titan PC Suite V7.2.
1. The current driver DMX1 / windriver two are now installed normally.
2. Insert the dongle comes a signal to the Rx.
3. If you run a T1 appears only continue starting titan phrase without going over the menu.
4. NET framemark 4.5 is installed ...
5. heck do not know the problem ... ㅠ. ㅠ
6. You've first tried to Avolites Titan PC Suite V8.0. Since then 7.0 / 7.2 will not run, but to install the version seen ...
Please help ..
Re: Titanone will not run.
Postby Gregory » 19 Mar 2015, 12:32
Unfortunately we do not support running under VMWare, we suggest that people running on Macs should use Bootcamp to run Windows.
nanchonnom
Postby nanchonnom » 19 Mar 2015, 14:12
Yeah .... ㅠ. ㅠ So, if Parallels, Inc. is possible ..? Are you using the virtual machine window should not ...? Mac is doegetjiyo course not ..? Is there anything to do to keep in mind when installing Boot Camp ...?
