Howdy.
I'm running the TitanOne on an Asus with 64-bit Windows 7 on 3 Gb RAM, Dual Core CPU and 2.3 GHz.
I work for a touring dance convention/competition company and we usually have the system up for 18+ hrs/day every weekend. I've had the show running on this system for about 2 days now
Twice I've had the Titan One software become unresponsive. I go into Task Manager, close down the Titan 8.1 program, but I cannot close TitanOne. Cannot close the process. Even in the command prompt I continually go through Taskkill and it says that the program is successfully closed, but it's not.
The only thing I can do is restart the computer and restart TitanOne and Titan 8.1 all over again.
During a dance competition, that means about 4 minutes of lost time. And that's not kosher with me.
Has anyone else experienced this issue? Is there a workaround? WILL there be a workaround? Should I throw my laptop against the wall?
Many thanks.
Freezing, will not close
Re: Freezing, will not close
The first thing I would check is all the power saving settings, particularly Usb. Make sure they don't have the ability to go to sleep. It may also be worth checking BIOS. I have a couple of machines that insisted on disabling the network adapter even when it was in use. Turned out to be BIOS level power saving.
Went in and futz'd with it. Fingers crossed.
