got some question on the avolites fixture fils system : how can i build a "custom fixture disk" ? I tried to copy just one fixture file onto disk and chose "Select Fixture" with the disk in and got no file found on this disk.btw i was an old pearl with the 2000 software and a r20 file.
any help would be appreciated.
pearl fixture file
mmarkaritzer
Chris Steel
With the latest Pearl software it is not necessary to have a listing file. All you have to do is copy across the .R20 files to a disk and then load the disk into the console.
If you do not put the file SG.dat onto the disk then you will find that the Shape generator will not work and you will need to load the shape file separately from the System Utilities menu.
If you have problems with the desk not finding any files on the disk then it could be one of the following problems:
1) The desk does not like your disk. Try a new disk and ideally format it in the desk.
2) There is an error in the personality file. Specifically check the device name.
If you want your disk to work on other Avolites consoles then I recommend you include a listing file.
