timed flash problem
morgan free
timed flash problem
Postby morgan free » 25 Jan 2015, 12:21
hello need to do a timed shutter flash and white to fade out immediately returned the shutter open position and the color of the time 5 seconds
Re: timed flash problem
Postby niclights » 25 Jan 2015, 12:51
- [Playback Options]/select white flash cue
- Set Intensity and Colour release mask to include either by pressing the [I] and [C] attribute group buttons above the wheel display or by selecting the [Release Mask] softkey then toggle mask source on softkey A to [Mask Source Local] then toggle [Intensity Include] and [Colour Include] on the relevant softkeys
- Set Release Time to 5sec by selecting the [Release Time] softkey and inputting 5 on the numeric keypad
This will cause the playback to release intensity and colour over 5 seconds. Usually because you are moving from a range (strobe %) to a fixed value (open), the intensity part will happen immediately and assuming you are using colour mixing for the colours these will release over a 5 sec fade.
morgan free
Postby morgan free » 25 Jan 2015, 15:25
the effect is supposed to look like this:
cue timed strobe flash white when relase strobe and color immediately passes with time 5 seconds
Postby niclights » 25 Jan 2015, 15:35
Sorry, I don't understand. Can you please explain what you mean by immediately and 5 sec? This sounds contradictory.
morgan free
Postby morgan free » 25 Jan 2015, 16:04
I set the cue in red permanently without strobe, I press another cue strobe flash white when the strobe flash relase stops without fade and slowly penetrates white in red
Postby niclights » 25 Jan 2015, 16:32
That is what will happen with the steps above.
