Error FAQ 10033
maivel
Error FAQ 10033
Postby maivel » 05 Jan 2015, 20:36
One does not start. Error FAQ 10033. I did not get any help from reading this faq. Any ideas. Simple reinstalling the software was not helping.
Re: Error FAQ 10033
Postby Gregory » 05 Jan 2015, 21:12
I assume that you are getting the error message, System Configuration Error!, when you start the software. Have you added or changed any hardware on your PC recently or updated any drivers? Is the time and date of the computer correct?
maivel
Re: Error FAQ 10033
Postby maivel » 06 Jan 2015, 09:22
Time and date is correct. Maybe the problem is the year is now 2015? :D Hardware is same, some usb devices connected, some not. Regarding the drivers I dont know, maybe some drivers update automatically.
maivel
Re: Error FAQ 10033
Postby maivel » 07 Jan 2015, 16:22
Hello? Any help from Avolites ?
kynk
Re: Error FAQ 10033
Postby kynk » 08 Jan 2015, 22:04
Try to uninstall/reinstall the suite, it might fix the files if some got overwritten by uptate etc
Re: Error FAQ 10033
Postby Gregory » 09 Jan 2015, 15:08
Would you be able to post the log files from your computer by going to Avolites > Tools > Log Collector in the Start Menu? In Log Collector, press Options and ensure that the date range covers the issue and ideally includes the last time you remember the software working. Then press the Go button then select a folder to save the log files to. The log files will be in a zip file with a name starting with Logs_ followed by the computer name and the date. The zip file containing the logs may be quite large, please can you post them to a file sharing website (e.g. WeTransfer, Dropbox, 4Shared) and post the link here.
jesperspier
Re: Error FAQ 10033
Postby jesperspier » 12 Jan 2016, 18:17
Hi Gregory, (or other)
Is this problem solved? I have the same problem (V9.1) sins i installed windows10.
Tried/checked:
-Reinstall
-system time
-firewall
-anivirus
-.NET framework
-Compatibility mode to windows 7
Any ideas?
Jesper
kimwida
Re: Error FAQ 10033
Postby kimwida » 04 Oct 2016, 05:22
It happened to me when I moved Win7 to Win10.
In my case, I solved it through changing my computer name. And reboot.
I changed Korean computer name to English computer name.
Anyway, you better check your log files as Gregory said.
jesperspier
Re: Error FAQ 10033
Postby jesperspier » 19 Oct 2016, 20:16
[quote]kimwida 04 Oct 2016, 04:22
In my case, I solved it through changing my computer name. And reboot.[/quote]
Thanks! After a year you helped me out! Changing my computer name (and change it back caus a lot of my network systems didn't work with a other name) worked!
