Hello
Can I change the break length in Titan one? I trying to do it but the values can not be saved.
break length
Re: break length
Where are you changing the values? The correct place is in System > DMX Settings. On the left hand side press the i button on the header labelled Expert DMX then in the bottom right hand side it will show you the settings. These settings will get saved as part of the show file, so make sure that you toggle to Load DMX Settings option appropriately when loading shows or starting a new show to avoid resetting the values back to defaults.
Re: break length
I already find the way how to save these values, thanks.
