Set value
nyholm88
Set value
Postby nyholm88 » 09 Dec 2014, 13:12
Ive had a few problems with the set button. As far as I understand. if you press the "set" button, you can set times for each attribute, instead of values. Then when you press set again, it should revert to setting vakues for pan/tilt...etc.
But a few times the set gets stuck, so I can only adjust times for fade and delay, and cannot get back to setting values for attributes.. I have to rebbot to get back to normal palletes..
Anyone else seen this
Re: Set value
Postby Gregory » 14 Dec 2014, 21:17
Softkey G in the main program menu toggles the values that are shown on the wheels between Levels, Fade Times and Delay Times. The Time button (which on some consoles is shown as Set) allows you to set overall cue times and pressing the Time button twice will replay the current programmer state using the times you have set.
nyholm88
Re: Set value
Postby nyholm88 » 16 Dec 2014, 01:18
Thamnks greg.
Yes that is all good, but what happens is I caht get out of the time mode once its in that mode. The set key lights up blue, and wont toggle back to normal.
Re: Set value
Postby Gregory » 17 Dec 2014, 10:07
To confirm, is it that you get stuck in the programmer times menu, the wheels are still displaying times or the LED is on? The LED should be on when you are in the menu or you have a time set in the programmer. There are options under the Clear menu to remove programmer times.
