chase in cue list
totalworks4u
chase in cue list
Is it possible to insert previously recorded Chase as a step in cue list, if yes, then how to do it ? Thanks.
Re: chase in cue list
You can autoload the chase from a cue in a cue list so that the chase will be fired whenever you are in that cue. In the Playback View select the Autoload column of the cue you wish to edit then select the chase (swop key) to add it. The chase will stop running when you go to the cue after, if you wish it to keep running add the autoload to subsequent cues as well. Note you can use range select either on the touch screen or using the wheels to change multiple cues simultaneously.
totalworks4u
Thank you.
Users browsing this forum: No registered users and 84 guests
