Titan Mobile all LED fixture colour values @ zero on clear
alexnnn
Postby alexnnn » 04 Nov 2014, 01:24
Hi, not sure if anyone else is experiencing the same thing but here is my issue:
Just downloaded avolites titan mobile v8.0 on a new computer, all sweet.
Added any LED fixtures, changed the colour values, press clear, always clears to 100%
In the past with previous versions of avolites I was able to clear to zero. Is there a setting in the software i can change to make it clear to zero rather than fade out to full colour?
Alexnnn
Re: Titan Mobile all LED fixture colour values @ zero on cle
Postby icke_siegen » 04 Nov 2014, 06:29
What fixture exactly are you talking about?
Essentially, colours shouldn't change upon clear, since they are LTP channels. I'd suspect a fixture with a virtual dimmer where maybe something is wrong in the personality.
alexnnn
Postby alexnnn » 04 Nov 2014, 10:58
Hey icke_siegen,
its on any led fixtures that I patch in, if you want to know an example; generic rgb 6ch mode, or james thomas pixelline 1044
Because before i even start playing with the colours of the fixtures, they are all at 100% is this normal?
When you say colour essentially shouldnt change upon clear is because you have left the 'freeze current values' on where as i want to go back to playback values upon clear.
Postby icke_siegen » 04 Nov 2014, 14:50
Yes, the 'power on' state is dimmer@0%, RGB@100%. This way, you just need to bring up the dimmer, to make the light shine. I can only guess that this is your issue: you just set the (virtual) dimmer at 100% with some playback. Then, your clear setting does effectively release the programmer to values set by playbacks - and if there aren't any, then it releases to power on...
Try creating a playback with some colour in it - at least in my tests it then released to that playback.
If this doesn't help, may I ask you to write down the button presses you are doing, in order to recreate exactly your problem?
Sebastian
