TitanOne and Capture
stevelights
Postby stevelights » 21 Oct 2014, 16:21
Before version 8, I used often TitanOne with Capture (Extended edition). No problem to visualize more than universe 1 and at least as many as 10 universes. Not anymore.
Is there a solution to see the rest of the fixtures patched to other universes in Capture?, without having to connect an AVO desk that is.
Thanks.
Re: TitanOne and Capture
Postby Gregory » 21 Oct 2014, 17:00
Titan Simulator will allow you to visualise as many universes as you want to Capture and do any offline editing to your show. When starting Simulator you will be given the choice of which console type you wish to run as including TitanOne. The option for TitanOne to automatically run in offline mode was removed as users reported that they ended up in that mode accidentally and were therefore getting the random DMX spoiler.
Sorry for the confusion.
stevelights
Postby stevelights » 22 Oct 2014, 10:11
OK for me now. Thanks.
So, Use the Tiger Touch Simulator rather than Titan One, and set the dmx lines with Broadcast: Universe ..#.. IP255.255.255.255. Capture finds all set universes without problem.
Now, in the ARTNET window of DMX Settings there is also available Capture(192.168.0.104):Universe 0,1,2,3 . but I think they don't seem to do anything yet. Do you know anything about that?
I can send screen shots if needed.
Postby niclights » 22 Oct 2014, 10:19
Try using broadcast universes.
