Hello everybody,
I would like to report a bug. Steps to reproduce:
Step 1.
Patch some dimmers, and create a few cues that have some dimmers at full.
Step 2.
Create a chase
Step 3.
For each step of the chase, include one of the previously created cues, and tap the blue button of the chase to store. Press clear after every recorded step.
Step 4.
Try to run this chase. You will see that the dimmers flicker some kind of random.
I hope you will be able to reproduce this. I ran into this on two different shows, both on the Sapphire Touch.
Best regards,
Stijn
Bug: Cannot create chase based on existing cues
Re: Bug: Cannot create chase based on existing cues
Will try it tomorrow.
However, because I saw something related with palettes, maybe you could try this: open the chaser in playback view (so that you see the step times). What do the Delay/Fade times per step read? 'Global', or '0'? If '0', then highlight this column, and select 'Use Global' from the function buttons. Maybe this helps for the moment.
