Hi guys/girls,
Is there a possibility to change the general mixing color for all your fixtures to CMY?
ie I've got 2 cmy spots and 2 led washes, is it possible to cmy mix that color for both fixtures?
Thanks,
Kasper
RGB CMY mixing
Re: RGB CMY mixing
You can use the colour picker in the attribute editor to control both CMY and RGB simultaneously or in version 8 you can create a global palette using one type of fixture and it will work for the other. At present there isn't a way to change the wheels between RGB and CMY.
Users browsing this forum: Bing [Bot] and 29 guests
