V8 only see custom personalities
sdhartog
Postby sdhartog » 08 Oct 2014, 20:47
I got the problem of not seeing the complete personality list, but only see the the custom (mine) persionalities in the fixture patch list.
The problem occurs after updating the personality list.
Titan Health check shows green status on Personalities...
Anyone have/had the same problem?
Sybren
Re: V8 only see custom personalities
Postby Gregory » 09 Oct 2014, 09:49
This may be due to one of your custom personalities preventing the software from indexing the entire library. I would suggest that you try moving all the custom personalities out of the directory and see if the main library reappears. If so you can try putting the custom personalities back bit by bit until you find the culprit. It might also be worth downloading and running the personality library installer again even if it shows that the same library date is already installed.
sdhartog
Postby sdhartog » 13 Oct 2014, 07:44
The problem is solved!
Yes it was one of the custom personalities. Some how, the problem personality file lost an end of file mark.
