Hello.
I recently programmed a show on titanPc suite, ment to be used on a pearl expert + touchwing.
However not everything seems to be working properly.
When i load my show, made on the pc, onto the console, groups aren't the same as i programmed them.
For instance i devided all spots into 3 groups and everything seems to be working fine on pc, but on the console group 1 will select all spots and group 2 and 3 won't select any heads.
I can fix this by just record the groups again and i did. But then i wanted to edit my show on pc suite again and the same problem arrised; groups are not converted properly.
Anyone else has a problem like this? any solutions? I'm running titanPc suite v8.0 and have v8 installed on my expert.
One more thing tho, not related to this problem but since i am here i might aswell just ask:
Occasionally when i start up the console, it will do its routine checkings when starting but then stays on "please wait" endlessly. I've had this since the first time i started the console.
When i power the console off and on again, it will startup correct.
Thanks in advance for any solutions/helpfull tips.
Greetings,
Harley
Show programmed on titanPc suite not working correctly.
