Show file on startup
Lars Huijgen
Postby Lars Huijgen » 20 Sep 2014, 19:11
Hello all,
I am probably just missing the obvious but every time I start up the desk (Titan mobile) it starts in the same older show file.
I red the manual and it says that it should automatically start in the most recent file, but it doesn't.
Does anyone know the solution for it?
Many thanks. Lars Huijgen
Re: Show file on startup
Postby niclights » 20 Sep 2014, 19:19
When you close the software it should save the current state and then load that when you start again. If there's a problem with this file or if it isn't there then it should prompt you there was a problem and ask if you want to start a new show or load an old one.
Please ensure you are running the latest version (at the time of writing v8.0).
If you start the software, go to disk, select [New Show], close the software and the restart, does it start as a blank show or is it still showing something old?
Users browsing this forum: No registered users and 83 guests
