BPM not working
Nicolas Espoz
BPM not working
Postby Nicolas Espoz » 15 Sep 2014, 20:52
Hi all.
I'm using PC Suite V8. I have a problem with the chase's BPM. No matter what BPM I assing to the cues on the chase, they jump really fast, not using the BPM's speed. The only way I can assing a speed to the chase is using "Delay-in" parameter, but the chase don't start when I need to cause the delay. So I really need to fix the issue.
I'm not a native english speaker, I hope you can understand me.
Thank in advance.
Re: BPM not working
Postby icke_siegen » 15 Sep 2014, 21:01
Sounds like an issue in v8.
Open the chaser in playback view (where you can see the list of cues). Highlight the column for 'Fade-In', and select 'Use Global' from the softbuttons. Repeat this for the column 'Delay-In'.
This should solve this issue.
