I've got a gig coming up where I'd like to "Slave" one pearl off another. Is it possible to do this? My thought would be to have both desks with the same patch on one DMX line, and have the 2nd desk merge the incoming signal onto it's output.
Any ideas?
John
DMX In on Pearl
John K
Chris Steel
Hi John,
Too slave 2 pearls together, all you need is a MIDI cable.
You plug it into the midi out of one console and then into the midi in of the other.
Then go into USSER SETTINGS and select the 1st console as MASTER, and the 2nd will be SLAVE.
You have to program both consoles and what will happen is when you bring up a Memory on the MASTER it will bring up the smae Memory on the SLAVED console.
One thing both console need to work with midi as some of the 1st Pearls did not have midi working on them.
But you can make them work, this is only aplies if you have a Borris 1 Mother board.
Any other questions please email me direct: chriss@avolites.com
