I recently had Avolites make me a new personality for a fixture. I synced the new library into my Pearl 2008 and Pearl Tiger. When I went to the unknown manufacturer heading (which is where the personality was placed) my board will freeze and say" Memory Allocation Out Of Memory" I have tried deleting all my old show files and have even erased the personalities and re synced them all. I don't have this problem when I go to other manufacturers in the list. Just the "Unknown" category. Is it possible this list is too big??
Boards have no issue rebooting, but when I get the error they freeze and I'm forced to shut down.
Thank you for any help.
Chad
PEARL 2008 Out of Memory
chadillac802
Re: PEARL 2008 Out of Memory
Hmm. Interesting. Not something I'm aware of but might be known. Will raise this as a priority. In the meantime it should be possible to work around by making some sort of custom personality list on a thumbdrive. Just ensure you follow the correct folder structure - if you extract one of the installers to a PC you will see how it works. The simplest solution could be to do this, delete all the 'unknowns' that you don't need and then copy the whole thing to a drive.
chadillac802
Thank you!! That worked. Just to let you know, I deleted 1300 personalities from the Unknown folder (I only kept about 100 one of which was the one I was looking for). I am able to access that folder with no issues now in both consoles.
I re wiped the fixtures from both consoles then synced the fixtures. This was after I deleted the files from the unknown folder (I simply accessed the folder on the usb stick and deleted many personalities being careful to stay away from the one personality I wanted). Now both consoles are running great.
Again, much thanks,
Chadillac
Again, much thanks,
Chadillac
