I would like to study the Avo family, without console, where can I get an Avolites Visualiser? I ve got Pearl 2004 simulator software, but I cant find the visualiser, is it not for free? Only Pearl 2004 available for controlling (with or without visualiser) in Windows (without console)? (Before unkind comments I've got expert knowledge about Grandma2, Grandma onpc and Ma3D, so I think I can made it at home
Downloading visualizer
Hi!
) Thanks for help!
Re: Downloading visualizer
You can get all downloads from the download page here.
If you want to use with Pearl 2004 Simulator then you need to download Visualiser from there and set the radio button to 'simulator' (you will have to manually add/patch fixtures into Vis to match the patch in the 2004 Sim.
If you want to learn Titan then download Titan PC Suite which includes simulators for all Titan consoles incorporating Vis. When used with Titan fixtures will auto patch in Vis if enabled (default).
You can find it at the bottom of this webpage :
http://www.avolites.com/software/latest-version
You should be aware that Visualiser7.4 is also included in Titan PC Suite and that, whereas it is meant to be loaded and used from within Titan, it can be loaded as a standalone software.
[Edit : Aaaand, I've been ninja'ed]
Thanks!
