Cue with only Phase
akepaulsson
Cue with only Phase
Postby akepaulsson » 21 Jun 2014, 20:16
Is it possible to do a cue with only Phase value? I would like to have one handle with pan for some moves, one handle with tilt and then the possibility to ad a Phase value for them on a separate handle.
Re: Cue with only Phase
Postby Gregory » 02 Jul 2014, 21:59
You can record a shape palette which only has phase information in it. To do this select the fixtures create a shape, change the phase to the desired value, press Off and turn shape pattern off then record the palette. If you want to use the palette without selecting the fixtures first (i.e. Quick Palette) you may be better recording the palette as normal so that it only effects the fixtures that you want.
