shape control and colour chase
randzchaggar
Postby randzchaggar » 14 Jun 2014, 21:05
Hi , im having trouble trying to figure out how to apply a shape over 'x' amount of movers but still have control over a simple 2 step colour chase , what seems to happen is the shape whats to restart with every change not remain smooth
im trying to do it on a single as im limited to channels on a Tm
many thanks
Re: shape control and colour chase
Postby niclights » 14 Jun 2014, 21:32
Try using a cuelist that contains the shape and autoloads a separate playback containing the chase.
randzchaggar
Postby randzchaggar » 21 Jul 2014, 23:11
any tips on how to go about it , still new to using titan
thanks
Quidam
Postby Quidam » 22 Jul 2014, 19:58
Autoload is covered by section 9.1.3 of the user manual.
Download it here.
9.1.3 Autoloading a playback within a cue list
You can program a cue within a cue list to automatically load one or
more playbacks when the cue fires. The playback can be a single cue,
a chase or another cue list. This can be a useful way to trigger chases
or effects from the cue list.
You can either automatically save active playbacks as Autoloads, or
you can manually allocate Autoloads to cues.
To automatically record active playbacks as Autoloads:
1> After selecting Cue List Record, turn on [Autoload Live
Playbacks] in the [Advanced Options] menu of the cuelist
record screen.
2> Turn on the playbacks you wish to load for this cue.
3> Save the cue. Active playbacks will be saved as Autoloads.
To manually edit autoloads:
1> Press [Playback Options] in the top level menu.
2> Press the blue Select button of the Cue List.
3> Press [Autoload].
4> The cues in the cue list are shown on the screen. Use Wheel A
to select the cue which is to have the Autoload set.
5> Press the Select button of the playback which is to be loaded.
The playback legend appears on the softkeys.
6> You can continue to add Autoloads to other cues, or press Exit
to finish.
The Autoloaded playback will be fired when the cue starts, and killed
when the cue list moves on to the next cue, unless you have also
loaded the playback into the next cue.
You can set options for each Autoloaded playback by pressing the
softkey where the Autoloaded playback is shown.
For a cue, the only option is [Remove this Autoload].
For a chase or cue list, softkey B lets you select whether to load the
playback from the start, to start at a specific cue, or to press Go on
the target playback.
