Workspace problems
WesleySLF
Workspace problems
Postby WesleySLF » 15 May 2014, 11:15
So recently i started working on a basic show file on our expert.
I made Some workspace views and assigned them to a handel.
Now during programming everythings fine but as soon as i save and shut down and come back
A day later, after loading the show all the workviews are shifted to other handles randomly and they cant be used.
All the legends of the views are gone asswel. Well you could say i can make New userworkspaces at Every beginning of Every show but that snot where the problems stops. After trying to use the previous used handles for my workspaces it doesnt do anything. I can assign the workviews to other handles and then move them over the original ones.
Am i the Only one with this problem
David Boots
Re: Workspace problems
Postby David Boots » 15 May 2014, 15:27
I am also having this problem, although its not with workspaces, I have been recording cues only to find them gone the next day and I cannot record anything onto the faders that had those cues... I have gone back several days worth of programming and found a show that seems to work fine... after thinking about this for a few days I have come to the conclusion that this possibly started happening after I entered the permanent license code. Olie? Could this be a possibility?
David Boots
Postby David Boots » 17 Jun 2014, 03:37
Update... I have done a dozen shows with no problems in the last month and then out of the blue I started having the same problem as before... nothing saves and you can no longer record anything onto those faders... I had to go back 1 week worth of shows to find something that worked.. I have a multitude of shows coming up where I load in at 8 am and the doors are at 12 and I really don't have the time to keep chasing these problems.. I just want a console that works dependably everyday.
Is anybody else experiencing this problem and what what are the remedies?
Thank you.
Postby niclights » 17 Jun 2014, 09:24
Just so you know someone is reading...
I have not seen any of these problems myself but I'm sure they are all related and have heard of other similar reports. Unfortunately I'm not sure of the cause or solution. Maybe someone else will have answers but I definitely think you should contact Avo direct if you haven't already. A phone call perhaps isn't practical given your location but an email to repairs and/or software can't do any harm.
Users browsing this forum: No registered users and 179 guests
