Legendary problems...hehe
ciuf
Postby ciuf » 24 Apr 2014, 11:34
Hi everybody,
I use titan 7.5 on TM with a touch laptop.
From the time I upgraded to 7.5, maybe also from 7.4 but I didn't notice, I am experiencing some problems with legends or stuff that implies writing in to spaces.
.1 Sometimes while I write a legend, I decide I don't want to do it anymore, hit "exit"...afterwards I have kind of a freeze of ALL the touch buttons, from fixtures to side buttons. It looks like the display doesn't get input, even from the mouse, but If I use the TM everything works, I wait a while, swet a lot, and the after 20 seconds I can work again. ( THE FIRST TIME WAS REAAAAALLLY SCARY!!!)
.2 I am not able to write notes on my cuelists, maybe this problem already came out because it reminds me something but I am not sure. If not I can add a video..
This happens all the times...and I have to say I really used a lot this feature and i MISS IT A LOT :-)
.3 I think this is a known issue but I thought it had been solved. When the desk starts up and autoloads the last show,the cuelists on the faders do not follow the "GO" command.
And with this I mean: While I skip through cues and I see the lights do everything correctly (except for my mistakes), the view cuelist workspace following everything, I don't see the same thing on the fader of the cuelist...solution to this , reload the show...
However, still having TONS of fun with this TM :-)
best regard and rock'n'roll
Sorry for my bad English....
Ciuf
Re: Legendary problems...hehe
Postby niclights » 25 Apr 2014, 18:29
1. Not sure. If it's consistent some steps to repeat would be helpful.
2. This has come up before. You can set notes using [Playback Options]/[Cue Options]/[Notes]. I'm not sure if it was previously possible to touch the relevant cell in playback view to do this but I did enter it into the system anyway.
3. I have also heard about this before but until now I don't think it was clear that it was specific to both loading shutdown show and the touch playback display area. I think there are other similar issues related to the touch (and HUD) display areas following a restart. I will enter it in the system. Note that for me I can solve these just by changing playback page - after that everything is good.
ciuf
Postby ciuf » 26 Apr 2014, 11:17
Hey,
1. I will try to make it happen as soon as I can...then I will send you video.
2.Yes, I was able to touch the note cell and write in it. What I have noticed is that in the latest versions of Titan the AVO touch keyboard automatically comes up when I want to set a legend or write something. What is actually happening now is that I touch a cell to edit,and this keyboard appears for just half of a second.
I think the problem may be somehow connected to this new upgrade...
3. Yes I know the page up page down trick. I hope Avo fixes this, it gives a sense of "not knowing what is going to happen"...
Thx Nic for the reply.
Ciao
