Titan one 7.4 impossible to patch dimmer
chavos
Postby chavos » 21 Mar 2014, 16:41
Hello i have a problem with titan one 7.4 full licensing
I start a new show and wipe dmx setting.
When y try to patch a dimmer ligne 1 dmx adress 1, i see on the right side of the screen the sign " ! " on the adress box.
I try different adress but the sign never disappear.
But when i try to patch fixture on ligne 1 dmx adress 1 it's ok it's possible to patch any fixture at any different adress on ligne 1.
I have try this on 2 differents laptop, but same problem.
I run window 7
any idea ?
Re: Titan one 7.4 impossible to patch dimmer
Postby niclights » 21 Mar 2014, 17:11
Sorry, I suspect this is my fault. The generic fixture was accidentally removed from the library yesterday. If you were unlucky enough to download and install before the mistake was spotted then you would not be able to patch a dimmer.
Please download a new library from here and install. If that doesn't solve the problem let me know.
ETA this would also occur if you did not have a library installed in the first place, although that would mean there would be no fixtures available either. In that case it would not be my fault :)
chavos
Postby chavos » 21 Mar 2014, 18:16
Ok now it's work
Thanks.
chavos
Postby chavos » 22 Mar 2014, 00:51
Same problem with the sapphire touch
i fix this by download the daily library exe
the faulty library exe is 19/03/14 downloaded
:D
