7.4 Issue
RenegadeMacky
7.4 Issue
Postby RenegadeMacky » 13 Mar 2014, 18:20
Am having some problems after updating the software to V7.4
After running and updating firmware for the T1, it started to become unrecognizable, software won’t pick it up, and usb expert console won’t run
Several times i have tried to “re-install” the usb drivers, and get the same error every time :
Error opening file for writing:
C:\Windows\system32\wdapi1100.dll
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file.
Is there any fix for this type of thing,
Alternatively, i have kept the older versions of the software, will i be able to roll back to 7.2 . That was rock solid and never skipped a beat for me.
Many thanks, and hope you can help
Regards
MikeMeester
Re: 7.4 Issue
Postby MikeMeester » 10 Apr 2014, 09:10
I Have the same problem.
The "RX" light is flashing and I can't update the driver.
RenegadeMacky
Re: 7.4 Issue
Postby RenegadeMacky » 12 Apr 2014, 17:02
MikeMeester wrote:I Have the same problem.
Hi mike, this may not help you, but "Unfortunately" my system died two weeks ago, hard drive just stopped, so had to do a complete re-install, everything new, from scratch, and it now appears to be working, stable too..
i'm thinking that there may have been a conflicting issue with previous / newer drivers...
however, now i get a new problem, but luckily, one that doesn't seem to cause any problems
running fine on 7.4 / and now the newer 7.5, allthough when i check in usbexpert console.. my panel shows up, but also shows a chip configuration checksum error, but this "Does Not" appear to cause any issues as yet :-)
there is an ongoing discussion with one of the avolites support team, after i check with them tomorrow, if it's allowed, i will post the responses i have gotten from this issue.. :-)
cheers
Users browsing this forum: No registered users and 61 guests
