Titan 7.4 Bug Report
Paul Heijkens
If you have any problems with Titan V7.4 please subject I'm here
Paul Heijkens
Re: Titan 7.4 Bug Report
You as my bug report I already sent this to Avolites and I hope it'll fix it soon
http://www.paulheijkens.com/PaulHeijken ... Report.pdf
If you have any other bug please submit them in a comment
Thank you Paul.
Please note this is not an official bugs thread.
In general I feel it is better to post separate threads for any suspected issue. The problem with placing large numbers into one thread or document is that it can become confusing and difficult to process. Internally they must be dealt with individually for the same reason. Additionally, historically many 'bugs' turn out to be user error or by design. By separating it is easier to determine which are actual bugs. Whenever this is the case they will be entered into the database for further investigation.
Nevertheless I will try to address each point...
To set cue notes use [Playback Options]/<select cuelist>/[Cue Options]/[Notes =]. Currently it is not possible to directly input or edit notes by touching a cell in Playback View. I'm unsure if this is a bug or by design although I agree it would be useful and should be an option. I will enter this. However, the important thing is there is a way to enter notes.
I can't repeat this. I have tried changing both the playback and cue legends along with text and scribble. In all cases after restart if I try to edit them they show the current legend. Please provide more information, preferably exact steps to repeat from a new show.
This is not really a bug. However, numerous people have requested that the list advances further ahead. So hopefully there can be some improvements to this in a future version.
I can't repeat this. I create a cuelist of 12 cues. I play the cuelist through until cue 10 is active. Press Record, select cuelist, set cue number to 10.5, [Insert]. Press go = cue 10.5 active. Please provide more information.
This has not been implemented yet.
I cannot repeat this. Make sure you have mapped your fixtures before importing the cuelist. If you are still having difficulty after mapping then please provide more details.
This sounds familiar. Could be an issue with Arkaos. This is more complicated to investigate so I will defer this for now.
I can confirm this looks like a bug.
I can confirm that the Set List workspace does not currently remember the view mode and always defaults to All Tracks on open. I will enter a request for this to remember/store in workspace shortcuts.
This can repeat this. Definitely looks like a bug.
Maybe there will be something in version 8?...
Reordering columns has been asked for before. Hopefully it will be possible in a future version. Different colour schemes/contrast could also be looked into but it would need to be an option - many people will find white backgrounds too bright.
While it is not designed specifically for the iPad you can still use it on one. Just search in the iPhone Apps.
It's not possible to write notes in the cue list
If you make Chase and give it a legend then restart the console you come change the legends. Well you can but the new legends will no show on the touchscreen only the old legend
When I'm running a cuelist A grey line Will show which cue I am running. When you have cuelist with let's say 40 cues the grey line will run down to the end of the page and then only when you hit go it will show only the next cue but not more.
If I'm running cue list and when I am at cue 10 ( for example ) and I want to program cue between cue and cue 11. I program cue 10.5. Then if I hit the GO we'll not play cue 10.5 but it will play cue 11
It's not possible to import workspaces from another show
When I import a cuelist the cuelist will run but the cues are empty. There is no dimmer information in the cues
Arkaos...<snip>
I delete a setlist. then restart the console the set list is back
If you choose the live track ( so only the live tracks you choose are visible ). If you didn't switch workspaces you will see that it will go back to All tracks
I made 3 setlists for one show in the order I want to use them. But when I restarted the console my setlist were completely out of order
Titan Net Back up improvement... <snip>
(Cuelist reorder columns)
Titan Remote improvement... <snip>
Paul Heijkens
Thank you for your fast reply
My idea for this page was to collect all the bugs so that i can befixed as quickly as possible
Next week i will try to make step by step notes of the problems i have, that you can not reproduce
Thank you.
I understand your idea behind the thread but as I explained above it is better if each issue is in a separate thread to avoid confusion and to avoid them getting buried and forgotten. It will end up being counter-productive. That is why we have never had such a thread before.
Any bugs (or feature requests) that are found here will be entered into the system for investigation and prioritisation by the developers.
clublights
Just to interject....
it would be nice if there was a page listing known bugs.
I noticed the set list bugs in V7.whatever it was when it was set lists were activated.
I figured someone else had already reported it so I've never said anything. if there was a list of known bugs we could review them and post new ones or know they are known and likely being worked on.
Paul Heijkens
Here is a short video where you can see what I mean
http://vimeo.com/89262399
password for the video= avolites
Looks like it is been fixed in 7.4 ( I can't reproduce it either )
I know see that it is possible but it's really confusing you can change everything in the cruelest view but I can't edit my notes
https://vimeo.com/89260227
That's perfect. I now understand the legend issue. It is very clear in the video - thank you for taking the time to do that. Videos are great!
The video about the set list order seems to end prematurely but I was already able to repeat this anyway. I made a mistake in my reply to this above and so I apologise if that confused you.
ChrisLITaz
clublights wrote:Just to interject....
Strongly second this request
Chris LIT
Lighting Designer
Project Manager
Creative Backstage Tempe AZ.
creativebackstage(dot)com
Chris(at)Creativebackstage(dot)com
Lighting Designer
Project Manager
