Titan Mobile, dimmer channels LTC problem
MontiDC
Postby MontiDC » 01 Mar 2014, 13:34
Hi
I just start to work with Titan mobile. And I have a LTP-HTC problem.
Though it is stated that dimmer channel fixtures behave HTP in my cue-list they do not.
If I set a dimmer channel to 0% intensity in a cue it is not recorded, thus remaining at the value from the previous cue
(It works if I set the intensity level to 1%, but that doesn't seem a nice workaround…).
The Patch has been made according to the manual.
I would be very grateful for a hint how to resolve!
Re: Titan Mobile, dimmer channels LTC problem
Postby niclights » 01 Mar 2014, 23:37
By default cue lists are set to tracking. This will mean that if a dimmer is recorded in a cue it will remain at that level for all subsequent cues until it reaches a cue with a new value. This includes zero. Therefore if cue 1 = dimmer @ 100%, cue 2 is empty and cue 3 = dimmer @ 0 % the output will be cue 1 = on, cue 2 = on, cue 3 = off.
So check that the cue actually contains the zero value - view playback and press the [View] button next to the relevant cue. If it is definitely there but the dimmer doesn't turn off then we can go into more detail.
MontiDC
Postby MontiDC » 03 Mar 2014, 20:05
Thanks for the quick response and help!
Only today I have returned to the project and seen that I can change the tracking in the CueList.
Now it works fine!
MontiDC
Postby MontiDC » 10 Mar 2014, 11:19
Sorry for bothering again.
It seemed that setting tracking to cue only would resolve my problem.
I saw your response only after I had programmed around 200 cues in cue only tracking mode.
And only then I realized that it means 1 cue only.
Still it seemed to work fine. I could include,edit, merge or insert, clear, then jump forward or backward and my cues were ok.
But as soon as I close Titan Mobile and start it again, I have some seemingly random behavior. Several cues have new channels in them or there are attributes changed.
I suppose it must have to do with sloppy use of the numeric pad, inserting a channel in several memories of the cuellist, so my actual question is:
Can I correct intensity/attributes of 1 dimmer/fixture in multiple cues of a cuelist and how would I do it?
Users browsing this forum: No registered users and 117 guests
