Merging palettes on PC suite?
ArieGroen
Postby ArieGroen » 28 Feb 2014, 09:17
Hi, on a expert i can merge palettes. So creating a color palette for my cmy heads on a handle and then creating the same color for my rgb heads. When try to save this to the same handle, it asks me to merge or replace.
But, when creating the same on my pc with my mobile, i never get the merge question. It just doesn't let me save to the same handle. Is there a way to merge palettes on the pc suite?
Arie
Re: Merging palettes on PC suite?
Postby niclights » 28 Feb 2014, 11:43
There is a user setting that toggles between [prompt for merge or replace] (default) / [always merge] / [palettes always merge].
There are two merge systems - [merge] and [quick merge]:
[quick merge] automatically filters (masks) the recorded values to match the attribute groups that currently exist in the handle.
[merge] will follow the mask and record mode set in the record palette menu.
When user setting [always merge] or [palettes always merge] is enabled, the quick merge system is employed. Similarly, quick merge is used when selecting the same handle a second time to confirm (ie. double-tap)
On Titan Mobile to merge a palette press Record followed by the destination palette handle. If [prompt for merge or replace] is enabled this will present softkey options to [cancel]/[replace]/[merge]/[quick merge] and a key to toggle palette type (within [quick merge] you will also see the mask that is going to be applied). If [always merge] or [palettes always merge] is enabled it immediately employ quick merge when you select the handle.
ArieGroen
Postby ArieGroen » 28 Feb 2014, 12:14
Thanks for your reply.
If I understand correctly, it should merge, or prompt you to merge, according to the settings. same as on the expert.
That's what I expected too since it's the same software. For some strange reason, it didn't do that.... I will try again this weekend.....
CU
Arie
Postby niclights » 28 Feb 2014, 12:26
Yes. Works fine here testing in 7.3.
Users browsing this forum: No registered users and 92 guests
