regards
edit saved shapes in memories pearl 2010
- zahoorjury
hi all .
is there possible to edit the shapes parameter in a previous saved memory in Pearl 2010 .i mean can we change the speed and size after ?
regards
regards
Re: edit saved shapes in memories pearl 2010
You can't edit cues directly but if you include the playback you can then edit the shape parameters and then record the cue again, replacing the original.
- zahoorjury
hi nick, thanks for the prompt reply, actually i am asking about a single memory on a playback handle not Chase , so again asking is that possible to edit a shape after saving into a single memory ?
The answer is the same.
