Shape jump with start and stop
Nicke Löfgren
Postby Nicke Löfgren » 13 Jan 2014, 21:38
Hi
Have a problem with the programming!
When I make a shape..... type Tilt Swing
When I turn on cue, so JUMP luminaires to a position, it will be the same when I shut down cue. Then JUMP luminaire to the starting position
How a do a soft start to the fixture starts stylish at position and ends in the same starting position??
I hope you understand my problem on my bad English :mrgreen: :mrgreen:
Re: Shape jump with start and stop
Postby niclights » 13 Jan 2014, 22:02
Just set a fade in and fade out time.
Nicke Löfgren
Postby Nicke Löfgren » 13 Jan 2014, 22:25
I try!
If i have high speed on the shape
When i start the Cue its start slowly to right speed! When i stop the cue its slow down AND JUMP TO THE POSITION :x
Postby niclights » 13 Jan 2014, 22:44
Make sure playback is set to mode 1 or it will only fade in.
Nicke Löfgren
Postby Nicke Löfgren » 15 Jan 2014, 10:31
Will double check and test some
thanks
