Atribute reverse prob on 7.2
sunlightevent
Postby sunlightevent » 18 Dec 2013, 21:25
Hi everybody
I have a TM and Ayrton moduled 150
on personnality fixture red green and blue are set like this : start value 255 / Endvalue 0
So I used to patch them and reverse RGB on 6.1 and all early version, everything worked perfectly
But doesn't work since 7.0 : Here is the result :
I patch them , reverse RGB attribute as usual
I [ locate ] them : Dimmer 100% and RGB 100% on screen but no light , so I move a little bit the wheels R G or B from 100% to 95% and then the light come to the value ( 95% in this case), It's the same when I recall palettes I have really strange result
I solved the problem changing the personnality file to a normal RGB range ( from 0 to 255 ) but I think there is a bug on 7.x and maybe it could happen on other fixtures ... Just to let you know
Regards
Re: Atribute reverse prob on 7.2
Postby niclights » 19 Dec 2013, 00:09
Thank you. I can repeat the issue with invert and locate. I think a similar bug has already been reported. Something seems to go wrong with virtual dimmer too.
Evidently the inverted ranges in the fixture are incorrect. I will fix this in the library.
