Pearl 2004 V1.1
Zydeco
Pearl 2004 V1.1
Postby Zydeco » 29 Jun 2005, 08:17
I made a color palette and recalled it, but there was no P on LCD.
I got channel level.
Is it an operational mistake or is it normal?
Or, is there a way to set something like it?
What I did is set the color at 50% and stored it as a palette on 31.
Then, I recalled it, but I did not see the "P31" on the LCD screen.
I did not use an edit palette.
Please let me know.
Postby niclights » 29 Jun 2005, 13:54
Did you have the fixtures selected when you recalled?
If you have Quick Palettes enabled in User Settings you can recall without having to select fixtures. In this case it is not entered into the programmer and therefore you will only see the actual values in the screen.
