Hello
On a show 2 days ago I had a pearl running 2004 v1.1 with 6*mac250.
After a day of programming, and about 30 minutes of show, fading pallettes stopped working. e.g. [select fixtures], [5], [preset add22] would no longer fade to the position pallette 22. It would do nothing at all. Though calling those pallettes without a fade time worked perfectly.
I have tried everything, [clear][clear][exit], key-program,[clear][clear]key-run-takeover,[clear][clear], checking for blind mode, calling them while in program mode, calling them from the [focus] menu. No matter what I did, if I entered a fade-time, the pallete would not recall. But giving no time worked fine. Shapes and position chases were also behaving normally.
After turning the desk off and on again, everything worked, but only for 30 minutes. After that it was the same problem again.
Any ideas on what this is??
pearl2000, boris II, vidcard + extended memory (check OK)
software 2004 v1.1
show was probably created in v1.0, edited in the pearlsim2004 and then loaded in the desk with v1.1
problem was for all pallettes (color, gobo, position)
showfile available if needed
Many thanx
Coen
pearl2004 fading pallettes stop working, bug??
I have managed to fix this problem and the new software version is currently undergoing testing.
The problem is isolated to the first 5 palette keys. If you happen to press these while running a palette then they lock out that palette slot. So if you happen to press all 5 of these palette keys while running a timed palette then you lock out all the palette slots and they stop working.
Sorry a bit difficult to explain but hopefully this may help you avoid the problem until the new software is released.
