Some problems here;
Set up is a TT V7, Arkaos Mediamaster(connected by art-net) and a bunch of lights.
Since the update from V6.1 to V7.0 the speed of all my pre-programmed video's has changed.
Value on the console is still 25% but the visual/content runs faster
With a looped visual it's hard to say, but i also use lipsync video's there i can see it perfectly,
How is this possible.
Also all my effects i made in the video are different,
For example; i had a split effect on a visual. Effect type; 3d, effect 4
When i fire the que now the not effect 4 but 5 is fired. So i have to set it back 1 parameter.
Nothing has changed in the arkaos or in showfile.
Also my msex still doesn't work.
And becouse the show is fully programmed its not possible to patch all the video layers again
This will result in loss off all my programmed video
Or is there an other solution for this
Any more people with this problem??
Thanks! Piet
Video issue
Re: Video issue
Can you please tell me whether the raw DMX values being sent by V6.1 and V7.0 have changed in DMX view. If they have then please send me both the V6.1 show and V7.0 shows and tell me the DMX lines and addresses along with the cue you are firing.
