Setting palettes to all fixtures in a playback
fluffix
Postby fluffix » 03 Oct 2013, 13:10
Hey there,
I want to apply a color-palette to a playback. The Manual says:
You can apply a palette to all fixtures in a particular playback. Hold the palette button and press the select button of the playback which the palette is to apply to.
However I don't have a multitouch screen. Is there any possibility to do that? Or do I always have to select the fixtures which should be affected?
Re: Setting palettes to all fixtures in a playback
Postby niclights » 03 Oct 2013, 15:03
This is referring to filtered palettes where you can apply a palette to only the fixtures in that playback, assuming relevant information exists in the palette. You can still apply non-filtered palettes normally either by selecting fixtures (manually or by group) then pressing the palette, or without selecting any fixtures in which case it will apply all the information in the palette to relevant fixtures. This is called a 'quick palette' and relies in it being enabled in user settings (default is enabled).
