Dmx output glitch
Foxtechnical
Dmx output glitch
Postby Foxtechnical » 20 Sep 2013, 13:13
I have had an infrequent dmx glitch with my T1,
It will randomly send all the movers haywire (pan/tilt/colour scroll) then back to the playback it was running before.
Has anyone else had this happen?
N.B. This was on V6 before I've upgraded and I haven't had it on a gig since the upgrade so I'm not sure if it's still happening.
Re: Dmx output glitch
Postby niclights » 20 Sep 2013, 14:10
That sounds like the spoiler that occurs when you don't have the T1 dongle plugged in.
Postby Gregory » 20 Sep 2013, 14:34
Make sure that you plug in your TitanOne before starting the software. Once the software has started check the indicator at the top of the screen about 2/3 the way across which should show Titan One but will show Offline if the software is in simulator mode with the spoiler.
Foxtechnical
Postby Foxtechnical » 22 Sep 2013, 22:24
I wonder if it's when the usb slips slightly, Almost if the dongle is a bit heavy for the slot.
I may try with a short usb extension cable.
