playback priority
totalworks4u
playback priority
Postby totalworks4u » 25 Aug 2013, 20:52
hello there, need some help with this issue. i need to have master playback for dimmer channel that can take over 5 other playbacks controlling dimmer channel of different groups of fixtures. i try most logic solution using the priority settings to get the result, but it did not work. i want the master playback to dimm out to 0 level all other groups that controlled by their own playback master.
thanks
Re: playback priority
Postby niclights » 25 Aug 2013, 21:49
Group masters should be available shortly in version 7. In the meantime try using mode 3.
