Expert simulator whit windows 8
mianroha
Postby mianroha » 22 Aug 2013, 19:22
Hi, can i use the avolites expert titan simulator whit Windows 8.... the problema i have is that there s a blue área arond the expert virtual panel display that dosnt allow me to use the buttons under it.... thanks
mianroha
Re: Expert simulator whit windows 8
Postby mianroha » 23 Aug 2013, 19:56
there waas a problema with my english.... the thing its that i CAN´T use correctly the pearl expert titan simulador on my pc with Windows 8, and i need someone to tell me if that is bug of the software or am i doing something wrong?... thanks again
Postby Gregory » 23 Aug 2013, 20:26
This is probably due to the Display settings in Windows being set to a scale larger than 100%. To change this setting, type Display into the Start Menu, select the Settings filter on the right-hand side, then click on the item called just Display. In the settings window select the option Smaller - 100% (default) and then click Apply. Windows may ask you to sign out and back in again to apply the change.
mianroha
Postby mianroha » 23 Aug 2013, 21:02
yes.... it was that.... thank u very much
