change palette from shared to normal?
As topic implies, how do i change a palette from shared to normal in titan?
Re: change palette from shared to normal?
1) select the fixtures you want the palette be applicable to
2) recall the (now shared) palette
3) <Palette>
4) [Record Palette] (Softbutton B)
5) with Softbutton C, toggle to 'normal palette'
6) select the touchbutton you want to store this palette on
7) if this is the same the previous shared palette was on, select 'Replace' from the context menu (Softbutton B)
3) <Palette>
Merge should also work. As far as I can remember in this case the normal will take precedence even though the shared still exists. Could be wrong...! Note that there are some known issues with the actual display of whether a palette is shared or normal (ie. 'N' or 'S' on the HUD or workspace handle) where they can become out-of-sync following a merge or replace. However, this does not affect the operation.
Users browsing this forum: No registered users and 98 guests
