how can i change the 0 pan position and range in the simulation so that it corresponds with the reality. my fixtures pan stat and finish position is decayed by 45 degrees.
pan/tilt range
eugenumail
Re: pan/tilt range
You need to edit the vis extension file, which usually sits in c:\program files\Avolites\Visualiser\Extensions.
First thing: check with the manual that the Pan travel corresponds with what is given in the manual of your fixture. In the following example I assume a fixture with a pan travel of 530°.
Then: Find the section beginning with 'ChanRef Pan'. There follows a line in this section containing something like
In order to rotate the default positions by 45°, you need to add (or deduct) 45 to both the values. E.g. if you add it, it would read. Or if you deduct it: .
Mapping 0 65535 -265.000000 265.000000In order to rotate the default positions by 45°, you need to add (or deduct) 45 to both the values. E.g. if you add it, it would read
Mapping 0 65535 -220.000000 310.000000Code: Select all
Mapping 0 65535 -310.000000 220.000000-
eugenumail
Re: pan/tilt range
thank you for your help.
And if i want to invert a channel (Iris), what values should i modify
// Iris
ChanRef Iris
Vismode Value
UseBits 1 2 3 4 5 6 7 8
DmxOffset 13
Mapping 0 127 0 1
Mapping 254 255 1 1
End
ChanRef Iris
Vismode Speed
DmxOffset 13
Mapping 224 239 60 600
End
// Iris
ChanRef Iris
Vismode Value
DmxOffset 13
Mapping 0 127 0 1
Mapping 254 255 1 1
End
ChanRef Iris
Vismode Speed
DmxOffset 13
End
Re: pan/tilt range
Change
'Mapping 0 127 0 1'
to
'Mapping 0 127 1 0'
'Mapping 0 127 0 1'
to
'Mapping 0 127 1 0'
