Dmx triggers
DUSTINSNYDER
Dmx triggers
Postby DUSTINSNYDER » 03 Apr 2013, 05:58
Hey. I am trying to use a leprecon 612 as a dmx trigger for my titan mobile running version 6.1. The midi in works just fine, but when I change the trigger type to dmx and give it a port (I'm using D) it tells me that It is being used as an output and would I like to reassign it? so I click OK then try to add the trigger i'm not seeing any incoming level. Also in this menu, I have the option for address, which defaults to 0. I'm not quite sure what the address is for or what it should be set at. I read in the manual that I may need to update my usb expert software to make this work and that a download was available on the avo website, however, I did not find this software anywhere. The only other thing is that I am using a 3pin male to male for the turn around with 3 to 5 adapters. Any ideas? Cheers!
DUSTINSNYDER
Re: Dmx triggers
Postby DUSTINSNYDER » 03 Apr 2013, 07:57
Update. I was able to update the usb expert doing the boot mode thing. Got some strange errors, but upon restart, the console can see the connected console.
