Change the HTP rule
dim_111
Change the HTP rule
Postby dim_111 » 01 Apr 2013, 05:55
Hi!
How can I change HTP rule to LTP in case of using dimmer channels?
For example, dimmer attributes of second cue list less then first cue list.
I fire first cue list, then second.
Thank you!
Re: Change the HTP rule
Postby niclights » 01 Apr 2013, 13:30
The only way you can do this is to patch a fixture that has a single LTP attribute. The obvious contender is generic LTP. Aside from the lack of fader control you should also note that it will not be possible to use dimmer shapes on these fixtures.
