@ Function Broken
CSmithDesign
@ Function Broken
Postby CSmithDesign » 21 Mar 2013, 15:28
Or at least it seems to be. I'm pre-programming and I can't do @20 for 20% intensity. Only @@ and @0 seem to work for 100% and 0% respectively.
At least this is what the Intensity display says, we'll see what happens on stage later today when I go live.
Postby niclights » 21 Mar 2013, 16:04
Works fine for me. Check user setting 'Channel levels set in units/Channel levels set in tens'.
With channel levels set in tens you would use @2 <enter> for 20%. @20 <enter> would give you full.
With channel levels set in units you would use @20 <enter> for 20%.
CSmithDesign
Re: @ Function Broken
Postby CSmithDesign » 24 Mar 2013, 15:34
Yep, that was it. Thanks.
