Pan&tilt swap save
Pan&tilt swap save
I have a PE 6.1 on a show with 12 movers and I swapped pan and tilt on 2 and had to invert pan and tilt on some of the others. Every thing seems fine until the console is re-started and then the 2 swapped lights revert to default Pan Tilt settings but the patch display shows them swapped. I have to de-select then re-select the swap and invert settings each time I restart the console.
Users browsing this forum: No registered users and 171 guests
