LED ARCBARS
sdm
LED ARCBARS
Postby sdm » 20 Feb 2013, 22:34
Record Arcbar 3 look onto a playback, put fader to full scene replays fine, pull fader down arcbars stay on. have to record off command onto another playback to kill them.
any suggestions ?
using Tiger Touch V6.1 running Arcbars in stage1 mode.
Postby niclights » 20 Feb 2013, 23:22
I'm assuming these are Showtec ARCBAR 3? If so, which mode did you patch in the console?
If you patched 'Mode 1, 12 DMX' this does not contain a virtual dimmer and so preferably you need to change to 'Mode 1 +vDim'. I don't know why there is a non-virtual dimmer. This should have been removed IMO.
Annoyingly I can see there appears to be a fault in the vDim code which means the Magenta attribute still won't be controlled by the dimmer. If you can't wait for an official update this is very easy to fix yourself either using Personality Builder or a cheeky text edit.
sdm
Postby sdm » 20 Feb 2013, 23:46
Yes Showtec Arcbar 3"s patched in mode 1.
This problem isn't critical just very annoying in both programming and running show
Programming tomorrow for show on Saturday so cheeky text edit or builder solution would be great.
sdm
Postby sdm » 20 Feb 2013, 23:47
Sorry yes patched TT in mode 1.
Postby niclights » 20 Feb 2013, 23:54
I'll just email you a fixed file. It will be quicker than explaining. I will add instructions in the mail where to place the file etc. If you haven't done any programming yet then just patch the new version, otherwise you can use fixture exchange.
sdm
Postby sdm » 21 Feb 2013, 00:03
Many Thanks. help really appreciated!
Might have have 6 crappy Arcbars wanting new home after this. spent more time on these than the rest of the rig.
Postby niclights » 21 Feb 2013, 00:11
Mail sent.
