Titan mobile dmx in problem
Baljo
Postby Baljo » 20 Feb 2013, 18:17
Hello!
I have a titan mobile and Pearl Expert console.
How do I connect pearl tiger to be trigger for titan mobile?
I do not know where I should set the DMX line in RX mode ... or what should be done in perl Tiger?
please help, it's urgent.
Thank you very much.
Postby icke_siegen » 20 Feb 2013, 20:18
On the Tiger, ou just need to patch some dimmer channels - one per fader.
Hook it up to the Mobile with a DMX male-male-adaptor.
On the Mobile, you need to assign triggers in system menu. This is described in length in the manual.
Just two hints: if your mobile is somewhat dated, please verify you are running the current software (6.1), and the firmware is updated. When the mobile was originally shipped with version 4, it didn't support DMX In. And: if you want to trigger cues and other stuff which is stored on touch buttons, make sure you assign the trigger to 'Trigger Type: Item" and "Trigger Action: Set Level". Else, if you set the trigger type to "Hardware", it would just toggle your button.
The DMX port is automatically set to RX mode as soon as you assign a trigger.
Baljo
Postby Baljo » 21 Feb 2013, 21:33
I've tried it all, everything like it is in the manual. I reinstall everything and now works.
Thank you for help. :))
