When I close and reopen the titan one software it seems ot forget any edits I made in the Vis set up.
all of the fixtures move back to the "default" position. this happens with auto update on or off.
if I reload the show from a saved section all returns to normal ( most of the time) I have had it lose the theatre set up a couple of times even on a show load from save till I saved it separately so I could reload with ease I had to rebuild it 3 times before I did this
Here is my set up
Retina MacBook Pro Boot Camp
Windows 8 Pro
16GB of RAM
512GB SSD drive
.net 3.5 sp1 and .net 4.0/4.5
All updates windows can find
Titan One Vis not remembering edits on restart
clublights
clublights
I did some testing ( including a complete windows /titan reinstall)
the problem is when you add a Generic Scroller + Dimmer
old shows ( from V5 titan) worked fine before adding a Scroller + Dimmer but failed as soon as one was added
Dittio for the Demo Show
Real pain for me as I have 10 of these on the show
How do I submit a bug report for Titan like this ? or will you handle it for me Nic?
The problem is actually more complicated than that, although I can imagine this is one example of how to cause it to go wrong. I have already entered details of the issue into the system.
As long as you manually save and load theatres it will always work correctly. Slightly annoying for sure but aside from remembering to load the theatre each time you start a session (and perhaps also having to move an extra file around if you are jumping between different consoles) it should not quite be the end of the world. I hope.
clublights
Don't worry about losing programming. Treat the theatre and your show as separate entities. Whenever you manually load a theatre it will restore exactly as when it saved and cannot affect any of the show programming. When saving (both theatres and shows) I highly recommend always saving often and always with new names each time just in case.
Users browsing this forum: No registered users and 2 guests
