How-to, Tiger Touch (titan 6.1) and Catalyst. Please help
frontal
Postby frontal » 16 Jan 2013, 09:50
My goal is to setup my Tiger Touch to be able to use a Catalyst media-server.
Can someone give me instructions on how to setup the console?
Regards,
Kurt
Norway
Regards,
Kurt Naeslund
StageWorks
Postby icke_siegen » 16 Jan 2013, 13:28
Where eactly is the problem?
- connect the Catalyst via DMX or Art-Net
- probably enable DMX control within Catalys (I must admit I don't habe a Catalyst - but this question is better answered in a Catalyst forum, I guess - try this: http://chaldee1.gotadsl.co.uk/~richardb ... /index.php)
- patch the required layers on your console (manufacturer High End)
Please know that the Catalyst doesn't support CITP, thus you cannot display the thumbnails on the console.
frontal
Postby frontal » 16 Jan 2013, 20:09
Thank you for answering my request :-)
I actually figured it out in the end, but I am more than happy if you will share even more links to good information on mediaservers that can be used with the Tiger Touch.
Regards,
Kurt Naeslund
StageWorks
Postby icke_siegen » 16 Jan 2013, 21:34
Hm, good information on mediaservers... this is a rather general question. I suggest you start your search at the respective manufacturers. In particular, the implementation of DMX/Art-Net control is only one small item in your decision pro or con a mediaserver.
In general, most nowadays mediaservers can be controlled via DMX and/or Art-Net. Also in general, please be aware that usually the DMX layout might change from one version to another - please don't blame this on Avolites! And, from experience I'd say the way how you like to program the mediaserver might greatly differ between any two operators - quite often it's the best way to write a custom personality for your own likings.
As far as I know, CITP (thumbnail) support works with the following models (again, this might depend from the very version):
- Hippotizer
- Screen Monkey
- Robe Digital Spots
- AI server
- Coolux Pandoras Box
- ArKaos MediaMaster
- Madrix
Other well-known servers (no CITP) are e.g. the Martin Maxedia, Highend Catalyst, D3, Picturall, and many more. And of course the MA VPU is a mediaserver, too - but you'd better ask questions about this elsewhere :D
<edit>
Furthermore, there are more special tools, like vvvv, Resolume Avenue and others, which fall under the term 'mediaserver'. But if you use such a thing, DMX/Art-Net usually needs to be activated via a separate module, and is definitely one of your least concerns.
And finally, there are some more simple media players. There is also one player for Mac based platforms (sorry, I forgot the name) - it's in the personality library!
</edit>
If I may be of more help, you are welcome to send me an e-mail.
frontal
Postby frontal » 17 Jan 2013, 07:43
Yeah, I know it was a very general question...but thanks for replying :-)
Regards,
Kurt Naeslund
StageWorks
