T1 with capture polar
joshbailz
Postby joshbailz » 14 Jan 2013, 22:30
Has anyone managed to connect T1 with capture polar? if so how do you do it, i understand its done using ARTNET but capture doesn't seem to be doing anything? Can anyone help?
john rogers
Postby john rogers » 15 Feb 2013, 09:55
Hi Josh,
Are you running Capture on a separate PC or the same machine as Titan One? I use Capture on my machine at work with Titan One so I'm sure I'll be able to help.
LightC123
Re: T1 with capture polar
Postby LightC123 » 08 Apr 2013, 00:49
I could use some help with this as well, I'm running it on my computer at the same time...
Postby niclights » 08 Apr 2013, 00:59
Have a look here.
LightC123
Postby LightC123 » 08 Apr 2013, 01:58
None of that helped :( Bothering me for quite some time
Postby Gregory » 26 Apr 2013, 20:11
If you are running both pieces of software on the same machine you may need to add the Microsoft Loopback Adapter which is a virtual network connection that allows applications to communicate with one another as if they were on two different computers. The loopback can be installed using the Add Hardware Wizard in Device Manager, instructions for Windows 7 can be found here: http://www.windowsreference.com/windows-7/how-to-install-a-loopback-adapter-in-windows-7/. Once this is installed, disable all other network connections (wired and wireless) to ensure that the loopback adapter is used by both pieces of software; you will need to re-enable the network connections again before connecting to another computer.
