Hello. I'm having trouble with ML's using "Locate Fixture" returning to 50/50. It says it's at 50/50, but it's off on both pan & tilt. Is there a way to move them manually to the correct position & then reset it to 50/50? I'm using Osiris SETH MR250S's. Also, they will not work with palettes. The THOT MR600SZ's do fine. I put in a bug report months ago and have not heard anything back. If anyone knows how to edit the personality file to fix it, I would greatly appreciate it. The filename is OSSM25S2.R20.
Thanks,
Bryan
Azure 2000 Reset ML Pan/Tilt to 50/50
The only way to change the locate values is to edit the personality. This is easy to do although you will not be able to retain any existing programming for these fixtures. Strange that they would be wrong though. If they are a long way out be certain it's not a fixture fault before adjusting.
Example of the code from Seth MR250 Spot Mode 2, 16DMX (OSSM25S2.R20):
The relevant values are currently 128 to the right of Pan, Pan Low, Tilt and Tilt Low.
Regarding palettes do you mean the 'preset palettes' that are an option to create automatically when patching or do you mean palettes that you create manually?
DMX
10 1 L 1 100 1N 0 1 "Control" 4 0 0
1 1 H 2 100 1N H 1 "Dimmer" 255 0 0
2 61 L 3 100 1N O 1 "Shutter" 14 0 0
3 61 s 4 100 1N E 1 "Pan" 128 0 0
0 0 L 15 100 1N E 1 "Pan Low" 128 0 0
3 1 s 5 100 1N F 1 "Tilt" 128 0 0
0 0 L 16 100 1N F 1 "Tilt Low" 128 0 0
4 1 I 6 100 1N A 1 "Colour 1" 4 24 14
6 1 I 7 100 1N I 1 "Gobo 1" 4 0 0
6 61 I 8 100 1N J 1 "Gobo 2" 10 0 0
7 61 L 9 100 1N M 1 "Gobo 2 Rot" 0 0 0
5 61 L 10 100 1N L 1 "Focus" 127 0 0
9 1 I 11 100 1N P 1 "Prism" 64 0 0
9 61 L 12 100 1N R 1 "Prism Rot" 0 0 0
10 61 L 13 100 1N 0 1 "Blackout" 14 0 0
8 1 L 14 100 1N 0 1 "P/T Speed" 4 0 0
ENDThe relevant values are currently 128 to the right of Pan, Pan Low, Tilt and Tilt Low.
Thanks for responding so quickly. It doesn't work with the preset palettes. I don't know about ones I created. The only ones I have created so far are position palettes using the 600ZS, and they don't work with the 250's. As for the pan/tilt, I think there may be a belt or gear that slipped.
Thanks,
Bryan
Thanks,
Bryan
